I had the same problem EVERY time i did that. I used the additive for the LSD in the gear oil... Problem is completely gone. You can get it from any dealer. Part # 00602-41301-101Drftn07 said:Does anyone grind going into second gear on the high revs, if so what can i do??????:shrug:
Lol all i know is that i work at toyota, i told the mechanic the problem, he did that, and problem completely solved. (its only been like 2 weeks but it hasnt grinded once)Drftn07 said:Wouldnt the grinding be in the transmission not the rear end. . .so how does changing the gear oil. . .help with the grind in the tranny???? please excuse me im not a motor head:brickknoc :brickknoc :brickknoc
The transmission uses gear oil inside of it to lubricate it. He changed the gear oil inside the transmission not the rear diff.Drftn07 said:Wouldnt the grinding be in the transmission not the rear end. . .so how does changing the gear oil. . .help with the grind in the tranny???? please excuse me im not a motor head:brickknoc :brickknoc :brickknoc
The mechanic did it for me when we were installing the S/C... it's $10 and goes where gear oil does. there may be a write-up somewhere on changing gear oil. Im not the best to explain it thats for sure. All i know is it worked lol.Drftn07 said:thanks :waytogo: i apprecitate it. . um where do i add the additive, or do they do it for you when you bought it. . . and it wasnt expensive was it????
Whoops i didn't realize i wasn't clear on that. Thanks GadgetGadget said:The transmission uses gear oil inside of it to lubricate it. He changed the gear oil inside the transmission not the rear diff.
Gadget
Shouldn't... just keep your records of when its changed.Drftn07 said:If i change my tranny fluid and diff fluid to redline oil it wont void the warranty wiill it? :selfbonk:
