1 - 3 of 3 Posts
Black 2dr Tacoma 4x4
Thanks for having me, I'm glade to be here.. I have a question. Not sure if this is the rt section but I have a 2006 Toyota Tacoma 4x4 2.7 230k miles The Deferential front & rear plus transfer case or the manual transmission has not been changed or checked in 7 yrs. Everything is running like it should ( knock on wood) But do I change all or just add to them ? Thanks Larry
(1) Welcome to CT, Larry.
(2) Are you referring to lubricating the differential / transmission / transfer case? If so ...
The 2006 maintenance schedule only says to check (and top up) these fluids at least every 30,000 miles or 36 months.
Limited-slip rear differentials are supposed to have their fluid replaced every 30,000 miles or 36 months.
Replacement of these fluids isn't specified until 144,000 miles or 12 years - and then only if the truck is used for towing.
1 - 3 of 3 Posts
