So I managed to get my hands on a white face gauge cluster with the built in tachometer. It is for an automatic transmission truck, so I have to cover the light up part for park, neutral, drive etc. Despite having a mechanical speedometer, I can order the adapter from Marlin Crawler to get an electrical signal to power the electronic speedometer in the new cluster: https://www.marlincrawler.com/transfer-case/parts-upgrade/misc-hardware/vehicle-speed-sensor-mci
What I don't know is how to get the rest of the cluster working properly. I connected it (all the plugs are the same) but the wires are all different and the new cluster lit up and behaved all wonky. There was no tach signal (expected) and the fuel gauge read incorrectly. Would anyone happen to have the gauge cluster pinouts for a 96, manual transmission, speedometer only, cluster? Also, the pinouts for an 03, automatic transmission cluster with tachometer? I have the extra pins I would need, so I can repin my connectors and add wires as needed to make the new cluster work.
