Toyota uses the term 'stabilizer bar' for what is commonly called an 'anti-sway bar' or simply 'sway bar'.
All Tacomas have a front stabilizer / anti-sway bar. However, the SR front bar is a different part number from the one used on other Tacomas.
The OEM rear anti-sway bar is unique to S-Runners during the period 2001 - 2004.
Diameters:
- Front: 1.1 inches (2002 listing) / 1.06 inches (2001 / 2003 / 2004 listings)
- Front: 27.7mm (as measured by CT-zen daveds50)
- Rear: 0.9 inches (as listed in Toyota spec literature)
- Rear: 23mm (as measured by CT-zen daveds50)
OEM Part Numbers: Front
  • Front Stabilizer (Anti Sway) Bar: 48811-AD040
  • Front Stabilizer Link Bushing: 90948-01080 (2 ea., both R and L)
  • Front Stabilizer Bar Bushing: 48815-AD020 (both R and L)
OEM Part Numbers: Rear
  • Rear Stabilizer (Anti Sway) Bar Assembly: 48805-AD020
    NOTE: Assembly includes the following pieces:
    - Stabilizer Collar 90387-10162 (both R and L)
    - End Bushing 90385-12015 (both R and L)
  • Stabilizer Link: 48830-AD010 (both R and L)
  • Link Bushing (2 per side): 48817-35010 (both R and L)
  • Bushing Retainer (2 per side): 90948-02032 (both R and L)
  • Stabilizer Link Bracket:
    R - 48809-35020
    L - 48807-35020
  • Stabilizer Mounting Bracket: 48823-35060 (both R and L)
  • Stabilizer Mounting Bushing: 48815-AD040 (both R and L)
Discussion Starter #2
Here (attached) is a photo from S-Nate-01 illustrating the way the S-Runner rear swaybar is mounted.
Here (attached) are photos of MountainBiker's installation of an S-Runner OEM rear swaybar on a 5-lug XtraCab of the same generation.
More info on MountainBiker's SR swaybar transplant project can be found at:
http://www.customtacos.com/forum/showthread.php?t=32404
He used the same mounting scheme as used on the factory S-Runners.
Discussion Starter #4
Here's an additional diagram illustrating the OEM parts.
