The power window on the front passenger side door of my 2001 Camry LE does not go up or down. Pressing the control switch on either the front passenger door or the front driver side door is ineffective - no sound or movement results. I just inherited this car and it seems in the distant past the window would do down when the switch was pressed, but not up. Now the switch has no effect at all.
I started to take off the interior door molding. It seemed simple enough, but I don't see how to disconnect the plate with the door lock/door handle mechanism behind the door panel. HELP!!!!!!!!!!!!!!!!!!!!!!!
How do I troubleshoot this issue? Is it necessary to purchase an online manual? If so what is a good one?
Thanks.
jjwt
Thanks.
jjwt
