Gunk engine bright...just cover your electrical and follow the directions.LBSLOCALS said:What is the best way to clean my engine, what should I use??
AZSCTACO said:Simple Green and a power sprayer
Where did you hear that???? :shrug:spyder041 said:nooo...simple green eats away at metals:runaway:
I thought it was the other way around - i.e., that 'Gunk' - style cleaners were corrosion problems because they contained caustic soda (lye) ... :shrug:spyder041 said:nooo...simple green eats away at metals:runaway:
Thats what I thought.........Simple Green is safe :waytogo: Been using it for yearsEnola Gaia said:I thought it was the other way around - i.e., that 'Gunk' - style cleaners were corrosion problems because they contained caustic soda (lye) ... :shrug:
"Simple Green products have been successfully and safely used on aircraft, automotive, industrial and consumer aluminum items for over 20 years. However, caution and common sense must be used: Aluminum is a soft metal that easily corrodes with unprotected exposure to water. The aqueous-base and alkalinity of Simple Green or Crystal Simple Green can accelerate the corrosion process. Therefore, contact times of All-Purpose Simple Green and Crystal Simple Green with unprotected or unpainted aluminum surfaces should be kept as brief as the job will allow - never for more than 10 minutes. Large cleaning jobs should be conducted in smaller-area stages to achieve lower contact time. Rinsing after cleaning should always be extremely thorough - paying special attention to flush out cracks and crevices to remove all Simple Green/Crystal Simple Green residues. Unfinished, uncoated or unpainted aluminum cleaned with Simple Green products should receive some sort of protectant after cleaning to prevent oxidation."
