When you want clearance with a 4x4 you add bigger tires. Of course you will be sitting higher with taller sidewalls. But your axle will have more clearance too! I strongly suggest, if you have a local spring shop, to get the springs de-arched. I got a 5" drop from my stock leaves this way and I didn't even have to do any flipping or changing of the order they stack. And it is real cheap. Of course the lower you go the more clearance issues you will encounter. The driveshaft may have added stress if you don't correct it. Are they angled 4" blocks? A 4x4 driveshaft worked well for me as it has a slip spline. Before I change anything I usually lay under my truck and visualize what it will look like and what needs to be done.
