1 - 2 of 2 Posts
Has anyone else had trouble locating the correct lower ball joint w/ mounting bracket from local parts stores? I'm looking for the correct Moog part number to replace my lower ball joint with the bolt on bracket for the drivers side of my 03 2wd ext cab.
The parts stores are trying to sell me Moog K90258 but that square 4 bolt pattern doesn't match what I have. My lower ball joint mounting bracket has the 'webbed' design similiar to the upper ball joint bracket. The other listing I found is for K90260 which doesn't look correct either.
Discussion Starter #2
I'm an idiot. The ball joint is in the bracket bolted to the steering knuckle, not the bracket bolted to the LCA.
1 - 2 of 2 Posts
