During the pandemic, I let my 2007 Taco, Double Cab, 4X4 V6 sit on the driveway. Well, to be completely honest, it sat a little before the pandemic started. So now I need to drain the gas and change the oil. I learned the hard way you can not siphon the gas because of measures put in place to prevent thievery. An internet search has suggested to jump the relay and use the fuel pump to pump out the gas.
I figured this was easier than dropping the fuel tank so I embarked upon this journey. Research said 99.9% of relays have 4 pins and they are marked 30, 85, 86, and 87. Furthermore, the diagram is also listed on the side of them. Well, a struggle and a half later, I safely removed the Fuel Pump Relay and SURPRISE!!!! it's 5 pins with no markings, and no diagrams.
I start doing research on the Denso 90084 - 98032 to see if I could find a pin diagram as I am supposed to connect pins 30 and 87 to have the fuel pump pump out my gas. Well, as it would have it, no such diagram exists. I did however stumble upon this diagram on a Toyota 4 Runner forum
I disconnect the front fuel line from the quick disconnect with yellow tabs. Attach a 3/8" rubber tube to the metal tube and run it into a gas can.
I checked for continuity and found continuity across 30 and 87a with resistance across 85 and 86. Everything checks out! So I disconnect negative battery terminal, stick in a paperclip, mistakenly across 87 and 87a, reconnect battery terminal, turn key to 'On' and nothing. I realize my mistake and repeat the process but this time, paperclip is across 30 and 87. Key to 'On' and still nothing.
To make sure I connected to the correct fuel line, I disconnect the other quick disconnect with yellow tabs and put a cup under that, turned my key to 'On' hoping it would prime, but nothing happens. I leave both tubes disconnected and jump pins 30 and 87 again, and nothing comes out of either tube.
Am I doing this wrong?
Alternatively, I have about 1/8 of a tank of gas left, if I can't get the gas drained, I may end up filling the remaining 3/4 tank with 91 octane gas, hoping it would slosh around and normalize enough to drive.
Your thoughts?
Thank you.
Your thoughts?
Thank you.
