1 - 17 of 17 Posts
So before I start to tear into my door, I want to know exactly what this sound is. Have a short video clip of it here...and its a lot louder in person.
It only does it when the window is all the way down. I'm guessing its the window rattling on its tracks but then again I could be way off. It does it when I shut the door, or when driving on bumpy road.
What is this, and the fix for it?
Waxed to Perfection
If you look on the inside edge (latch side) of the door you will see a small metric bolt head under the latch.. tighten it up.. This bolt holds the window track frame secure.. Do not over tighten, it is breakable.. And its metric 6 x 1.00mm (Part # 90901-19029)
Moonbeam
x2 sounds like the window to me
Thank you for posting this. I have a 2010 PreRunner which doesn't appear to have that bolt. Do you have any other suggestions?
I'm not completely sure that this is my problem. The best way I can describe what I'm hearing is like the door isn't closed all the way. I've checked everything I can think of and everything is tight. Thanks.
Do you mean the whole door seems to be rattling, rather than just the window glass or some component inside the door assembly?
Does the door shut tight, and is it flush with the body when closed?
It's possible for doors to work loose or get misaligned at the hinges.
I was originally thinking it was the whole door, but now I'm pretty sure it's the window (or some component inside the door) that is rattling.
My guess would be that something in / on the window glass's lifting frame (or whatever it's called) has worked loose.
1 - 17 of 17 Posts
