1 - 1 of 1 Posts
Tire Wheel Motor vehicle Automotive tire Tread
Bicycle part Bumper Camera accessory Gas Automotive radiator part
First post here. So I did the QA1GS501-10550A coil-over conversion + Fabtech FTS4130-7 lift spindles + Doestech 75090 UCAs on my 1997 2wd 5-lug Tacoma.
I bought the conversion plates from @mjbtaco and welded them to the LCAs after some grinding and had a friend PC them. I also had some Doestech UCAs and Fabtech spindles from an auctions on eBay laying around so I used those.
The only problem that I am dealing with is that I am getting negative caster unless I shim the rearward caster/camber shim to maximum stack height. And then I only get less than a degree of positive.
Tell me if I am insane but I stacked the stock drivers UCA and Doestech UCA on top of each other and aligned them via the ball-joint mounting holes and it appears that the Doestech UCA actually decreases caster (pushing the ball joint further towards the front of the truck). I am thinking of swapping the drivers and passenger UCAs to see if that gives me positive caster again. Need input.
1 - 1 of 1 Posts
