Just wanted to let you all know. I was swapping out my tires this weekend and noticed that the right front A-arm bushing was failing. The A-arm is actually pushing the lip of the bushing over the outer washer. These are the same washers that were supplied with the kit. These washers are NOT the same diameter as the bushing itself allowing it to flex over the outer washer. I noticed on the DJM website that the pictures they currently show DO match the diameter of the bushing. Did this change recently? I'm not too sure. My kit was purchased in 2001. I just got off the phone with DJM and they will be shipping me new bushings and washers asap (not sure if it's gonna cost me or not). I don't have any pictures currently, but I'll try to get some up when I swap out the hardware. Might want to check yours out too just to make sure the diameter of the washers matches the bushings so it doesn't push over.
I'm sure I saw this posted on here before, but couldn't find it. Maybe Randy could work some search engine finess to find the posts?
