1 - 5 of 5 Posts
hey guys just had 3/4 kit installed....front end riding a little high...the shop told me with an alignment and some driven the front end will settle down...is this true or you think they didn't flip the ball joints???????
LOOk! If they indeed didn't flip the ball joints you will see them underneath your lower control arm. If they did you will not see them. Just lie down in front of your truck and look! It could be that it does need to settle down but it depends just how high your front end is sitting!
Discussion Starter · #3 ·
Well finally got my truck all fixed up and lowered properly....I ended up taking it to another mechanic and he flipped the ball joints....The first shop had done everything but that....but the nightmare is over...will post a pic as soon as i can...
Discussion Starter · #5 ·
Re: Hey P.T.
i had a problem because the shop that initially lowered it did not flip my ball joints so the front end wasn't actually lowered....but i got it all straightened out....and you use your stock ball joints with the djm kit....
1 - 5 of 5 Posts
