1 - 16 of 16 Posts
Ok, i'm not aware of any writeup on recovering door pannel inserts in my gen taco, so here it goes...
Step 1: Gather tools and materials (no pics of this...)
Your going to need at least the following..
01-04 taco with electric windows
Philips head screwdriver
Two hands
Xacto knife of flat razor blade
A spatula or credit card to soothe the material out
a dull dull butterknife or you can use the spatula for this as well
somethign to pry the little plastic plugs out of the door
spray glue
and your choice of fabric
(beer optional :waytogo:)
Now here's how to take the door pannel off
Step one...
this is what it looks like before you start
Step two
Start by removing the window switch panel.
Do this by working your fingers in there between the door panel and the switch panel in the front, it will pop up , and then you slide it forward..
Step three
Depress the little tabs on the connections, and unplug them from he switches.
(dont worry about remembering which is which , they cant be mixed up)
Step four
There's a single screw holding the door handle on, remove it with a philips screw driver
(remember lefty loosy;))
Step five
the door handle will not just fall out, you have to gently pull on the front of it towards the door jam , it will release and will hang there
Step five.1/2
pull the door handle away fromt he panel a bit to make sure it wont get hung up in it
Re: DIY: How to recover yout 01-04 door pannel inserts
Step six
take your prying tool and carefully pry at the bottom of the plastic plug, and pop it out.. Dont mind my scratches, i dont care about them... remember to pry out the other one beside it as well
Step seven
there's a screw behind both plastic plugs, its quite long , about 1.5 inches and its semi hard to find with the screwdriver as well, so dont get dissuaded...:waytogo:
Step eight
here's where it gets fun..
starting at the bottom by the speaker, pop off the door panel from the door, its held in by plastic pop in plugs... dont be scared, i've never broken a plastic plug ( dont send me hate mail if you do:lol:)
Step nine
Continue on the bottom edge of the door to the other side continuing to pop off the plugs. there's also some on the vertical sides of the door, so check for them as you go...
eventually you end up with all them disconnected, and you can start to push straight up with a twisting motion with the rear rising higher them the front..
when you get all the way up the top of the door will be out of the windown chanel, but dont run off with the door just yet
Step Ten
once the door is out of the channel, you'll have to twist it around the door handle and it'll come through the panel
Step Eleven
unplug the tweeter connector and your home free
Step twelve
Start by disassembling the door panel. were going to be removing the arm rest
there's seven screws hold it to the panel..(once more dont send me hate mail if the count is inaccurate...) the screws are circles in green
Step fourteen
this is what the door panel looks liek striped and ready to get down to buisness.. i'd say take the time to clean out under the arm rest, i guarentee its filthy, and also the whole panel as a whole in prep for taping.. make sure its exteremely dry and oil free before you start the next step..
Step fifteen
Start laying the tape down.. the purpose of this is to prevent glue from going where you dont want it, and you onlywant it ont he cloth.. dont worry about overlap on the cloth, we'll cover this next
Step sixteen
Next its time to whip out the razor blade or exacto knife as i prefer, make sure its a fresh blade and very sharp...
what your going to do is stick the blade down in the chanel that the cloth is shoved down into and run the knife around the whole thing making sure your tape is covering the plastic door panel,.. it can be tricky but take your time, and if you screw up , throw some more tape on top of the bad are and try again, its ok to do patch jobs:waytogo:
Step seventeen
Time for the glue, whip out your spray glue and spray it on the cloth, spray it on pretty good making special sure to get it int he grove where the cloth sits in..
i'd recommend doing this outside for obvious reasons:waytogo:
Step eighteen
allow the glue to tack for a minute or so, and its not time to lay the cloth on..
lay it on from one end to the other, taking special care not to have any wrinkles or humps or air bubbles, stuff of this nature.. if you've ever laid vinyl stickers, you know how to do this..
use the spatula or credit card to help smothe out the wrinkles
Step nineteen
no pics, however take your dull butter knife or spatula and start vigorously shoving the material in the cracks, get it in there good and as far as you can
step twenty.
once again get a frech blade, and start running the blade in the crack aroudn the panel liek you did with the take, cutting off the excess material as you go.. if the blade gets hung up and pulls thematerial back out shove it back in imediatly
, you shoudl end up with something like this
Step twenty-one
no picture once more, but cut an x in the material covering the door handle opening, being careful not to cut too far and expose the material underneath
Step Twenty-two
reinstall the door panel on the truck, and have a beer and celebrate(if your of legal age of course;))
yes this is my drivers door panel, no pics of the passenger installed
BONUS PIC(me enjoying beer and working on cars:lol:)
hope this was helpful, if not make your own damn how to:nana:
Re: DIY: How to recover your 01-04 door pannel inserts
Great writeup, Chris! Thanks! ... :waytogo: :bow:
The two tone door looks nice. You might want to leave your party hat and "prying tool" at home when you take her for a spin :D Thanks for the pictures..... they speak so much louder than words.
Matt
Dude, that looks bad a$$! Been thinking of doing that to my '04 but not sure what the outcome would be. Def gonna do it now!
Thanks for the write up...:clapping:
Oh...just a little side note. When you take the screw out of the door handle, hold the handle out a little. There's a small clip that holds it to the door pull mechanism. You can just pop it off and take the entire handle off. :)
Howdy! resurrecting this super old thread, hoping someone checks in on this, just a quick question: what material did you use (looks like cloth), and most importantly, where did you get it? Been having a hard time locating the upholstery material, short of just walking up to a shop and asking them to sell me some stuff. Thanks!
Excellent! Thank you! How has it been holding up over the years? I don't want to rub it raw in a year or two, as I plan to wrap high-use areas like the center console and arm rests as well.
1 - 16 of 16 Posts
