1 - 17 of 17 Posts
Discussion Starter · #7 ·
It can go wherever you would like as long as its after the maf. When I had my truck I sprayed post throttle but pre throttle would have been fine as well. On a turbocharged truck I would spray after the intercooler.
back in black (tacoma)!
WideOpenTuning said:
I have 2 Devils Own water injections systems for sale. Both are brand new, One is the basic kit http://www.alcohol-injection.com/universal-base-alcohol-injection-kit-p-8.html
And the other is a progressive kit with controler for $275 shipped
http://www.alcohol-injection.com/universal-progressive-alcohol-injection-kit-p-12.html
These are really easy to install as well. Devils Own has pretty great customer support.
On the basic kit, what size nozzle(s) do you have and what pressure range is the pressure switch? And do you have a tank?
2x
Wondering the same thing.
I just got my Water Injection system running not too long ago. I like it alot, thing with this one is you can not turn it on till 6 psi with the boost pressure switch.
Gadget got mine coming on right after boost starts and the increase is nice compared to no water at all using the AIC controller.
Might want think about that, how many here are running their WI to come on at 3/4 to full boost, most are probably earlier in the boost range than that. I have a 9psi pulley and just regular driving I get in to boost fairly easy so that switch would not work for me. Now that I think a little more about it I am just a S/C guy, I know nothing about turbos with or without intercoolers.
Sam
Do these come with a tank? What size nozzle and switch do you recommend for a 2001 3.4 taco with the TRD supercharger? I am running stock pulley on the supercharger.
1 - 17 of 17 Posts
