I have a dent that goes through the door , cab corner , and the bed on the bottom body line. It isn't a solid streak , but skips every few inches. On the bed , it looks like the dent moved the panel in a little bit and the transition between the cab and bed isn't straight , or is it like this from the factory. I tried to look on the driver side to see it was the same , but i can't tell. You can stand back and see the panel is off. If i took the dent out with a hammer and dolly , will the panel pop back out , to match the cab. The top part of the panel on bed matches the cab until about half way down were it starts to move in.
Thanks For the help,
Dirk
Dirk
