Thanks everybody...I think i'm going to try the 3/4, pull the bumpstops, and some new Toxic shocks and see how things go from there. Is there any way to install a SMALL notch in the frame that doesn't require cutting the bed? And what would it cost (if possible) to bag the rear...don't want to lay frame, WILL NOT cut bed, would just like to be able to get a little lift for driving if needed...and can bags be setup to fill from like a tire compressor, i.e. without an onboard compressor, and how much cost difference would the compressor make?
Thanks a ton for all the info you guys, I've had my truck only 2 weeks and i can't wait to get started on things!!
'99 2wd Xtra cab
