COMPLETED: Bench to Bucket Swap 2007 Regular Cab
3677 Views 10 Replies 4 Participants Last post by  Phil R
I swapped by bench for buckets this weekend. I bought a 2007 Reg Cab M/T 4-banger a few weeks ago. The bench had to go. I didn't have a camera handy while I was doing it, otherwise I would have taken pictures for everyone. I'm not 100% complete with the swap, so they next time I pull the seats out, I may take pictures.
I didn't use OEM toyota seats. All of the local junkyards wanted too much for them: $250/seat.
I took measurements of everything 2 weeks ago and spent the day at my local pull-a-part and grabbed the bucket seats out of a 99 Isuzu rodeo. While I was there, I pulled seats from a few Honda cars, an Eclipse, a Celica and a MKIII supra. All late 90's models.
The Rodeo seats looked the best and had the best overall dimensions, as in, they had a narrower track width and the actual seat rails/brackets were shorter than OEM measurements, so I knew I could get them to work - but I knew I would have mount them myself.
Disassembled the interior. Removed everything in my way: Bench, sensors, center console, door sills (these just pop out), center/child seat belt, etc. Folded carpet up and forward to get it out of my way.
Driver's Side:
On my 2007 Standard cab, the front seat mount is raised and had bolt holes w/ tack-welded nuts in both right and left sides of the raised mount for OEM buckets. The OEM buckets have a wider track width (~18"), where the rodeo buckets I used had more of a ~15 and 3/4" track width. I used the outer (left) OEM bolt hole and marked and drilled a new hole to match the width of the inner (right) Isuzu track. Tacked a nut in place under raised mount to hole the inner or right side bolt. Used OEM bolts in front mounting. Example:
Code:
   ^ Front of truck ^        OEM Right mount
            =O==========O==O=
OEM Left |                      |  \
    mount  |                      |   New Mount drilled for Isuzu Bucket
               | <-seat rails->  |
The isuzu rails were not even. The inner rail was about an inch shorter that the outer rail. I had to unbolt the inside rail / track from the both seats and raise them. I used longer 40mm M8 x 1.25 bolts and used 3/8" inch nuts for the spacers. 3x 3/8" nuts equaled an inch and made both sides of the seat rails parallel or equal. The nuts were slightly larger than the metric M8's so they just slid right over the longer bolts. This should be self-explanatory and I hope every gets what I am saying. But if not:
Code:
  Seat bottom
                  /_____________\
Outer Rail      |                     Inner Rail (right side)
     (left)
           So I had to make one longer to even them out.
Once they were even, I fitted the front bolts and lined out the seat and marked the location for the rears with a sharpie. I had to bend the actual seat mounting tabs with channel-locks about a degree or two to make them even with the Tacoma floor and front mount.
Drilled holes for the new rear bolts. Tacked bolts in place under truck.
Rinse and repeat for passenger side. Re-assemble truck. Lots of little black circular stickers covering holes in rear of cab. Since I drilled new holes for different seats, these were not used, but I'm assuming if you used OEM seats, the holes are pre-drilled. I can check to see if nuts are tacked in place for any of these holes for OEM rear bucket seat bolts. I forget to check on this.
I'm still working on the sensors and etc. I re-used the Bench seat-belts. I have most of the sensors mounted to the new Buckets, with the exception of the pad that detects if a passenger is in the seat and enables the airbag.
Hope this help anyone who wants to swap. I know a lot of people want to do this and the information is sparse.
1 - 11 of 11 Posts
Sounds good ...
Thanks for taking the time to document the issues and the installation. If possible - please post some photos once you're done (or whenever). To the best of my knowledge, yours is the first Isuzu seat transplant documented here ...
... And Welcome to CT! ... :waytogo:
hey thanks. I ran out of time while typing this up - had to leave, so I'll clean up my post later. I didn't think anyone had done a rodeo transplant. Only reason I did was availability.
Pics and diagrams that understandable coming soon!
Fixed my diagrams. It's raining here now, so it will at least be another week or two before I take the truck back apart to take pictures of the cab with everything out. Wife has the truck today, but I can take pics of the finished install later today and attach them.
Seems good enough. Did you tap new holes for the rear mounts and then slide in hardware and then you welded the bolt in place? I did a write up on seat sensor removal awhile back. Getting the seat weight sensor will be a bit of a pain depending on how the rodeo is upholstered. Don't forget to mount the seat position sensor as well. Without either of the two the airbag will not deploy. What you doin with those supra seats?
5
Yeah I bolted them in loosely then tacked the nuts only from underneath; So the bolts are not welded. I even went a step further and used a paint stripping wheel and cleaned up the area and covered it in JB-weld. So the rear nuts under the truck are not coming off unless they are cut out. This job is not hard, that's for sure. No welding is required provided you use the right hardware. I even used a little dab of red thread lock (permatex).
For the inner front nut, I tied a string around it and used a magnet tool to hold it in place. I got the bolt started with a much-much longer M10 bolt I have in my bolt/nut bucket. Pulled up with one hand and tacked it with the other. This was the hardest part of the whole job. In retrospect, I could've just made a flat bracket bolted or tacked to the inner seat track mounting tab and used the OEM inner bolt holes.
I haven't figured out just yet how I'm going to get the seat weight sensor working. I stripped it from the bench already, but didn't take the Rodeo seats apart because I ran out of daylight Saturday. It took me about 5 hours to do this whole job, this is including going to the hardware store to pickup some larger M12 bolts/nuts for the rear and longer M8's to even the seat tracks out.
The seats sit about an inch lower than the bench, which I like. I knew they would going into this, based on my initial measurements.
Sorry, what I meant was I pulled seats out of a lot of cars, then compared all the seats. I only bought a single set of seats and left the rest at pull-a-part. I pretty much excluded the Celica and MKIII Supra seats because the driver's side was electric and neither were in as good of shape as the Rodeo seats. My local pull-a-part has a limited selection of decent seats - people tend to throw motors/transmissions/everything else in the car interiors and ruin them. Seats cost me $50 w/ tax.
I actually own a '96 MKIV Supra, which is what prompted me to buy the Taco. Didn't want to drive my supra to work anymore. So this IS my work truck.
What did you do with the bench????????????????????????????????//
I broke off the mount from the bench and then welded that to my passenger side seat frame so its close to where it use to be. I also took apart the wiring harness so that I could wire the seats seperately. Here is a link on how I did my buckets.
http://www.customtacos.com/forum/showthread.php?t=139676&page=4
Nice. I like that setup. I got my seats so cheap I was trying to go extremely low-budget and just "make them work" without too much fabrication. Your setup is much nicer with the custom-made bracket IMO, but I'm not 100% sure I'm keeping these seats. I know I'm getting seat covers soon.
PRO's of the Isuzu seats - smaller width/track/overall depth. More room behind seats for stuff like tools/audio/electronics. Easy install, minor modification. CON's - They are seats out of a 99' Isuzu Rodeo :(; a POS if one ever existed. Not a con for me, but roughly 1" lower seat height. Maybe having to drill new holes is a con?
Still have it. Sitting behind me in my office. Birds shat on it while it was sitting on my back porch Sunday. No plans for it.
Thanks, but yeah I had to make the mounts due to the seat height and not wanting to drill hoies. And yeah my bench is sitting in the garage right now.
1 - 11 of 11 Posts
