Using seperate relays per side, you can use the parking light as your signal turn on. And use the running light power on as your signal turn off.
Two 55 w bulbs are just 11 amps most relays are 35/45 amps. I ran 12 gauge wire and two 100w bulbs. That is about 16 amps. Ran that set up for about 2 years. No problems.Exactly like Phil said. you can get away with using a single relay if you stick to the stock 35w bulbs. but if youre gonna use 55w bulbs id use 2 relays
Did you do them to work with just the parking lights or do you have it setup to turn off with the driving lights like you originally wanted?ya i had my friend help me we wired the fogs up with one relay from advanced and then split it to the two wires, also we hooked up a e-fan and a thermostat from advanced so it comes on right when the radiator gets to a certain temp, i will put pics up asap
Consider yourself lucky. The stock parking light circuit was not designed to handle to the extra load (amperage) of aux. lights.I have my fog lights spliced into the power wire for my parking lights and it powers both no problems. No relays or any fancy stuff :shrug:
naw they stay on with the driving lights but i like um just fineDid you do them to work with just the parking lights or do you have it setup to turn off with the driving lights like you originally wanted?
