1 - 20 of 22 Posts
Discussion Starter · #3 ·
juss wondering cause my uncle wants carbs in his tacoma juss to be different. i also read on other sites that its impossible cause the jets are mounted on the head unlike the 22r the jets are mounted on the intake manifold
Discussion Starter · #7 ·
thanx for the info, and yea efi is more powerful cause i beat hilux running performance clutch, weber downdraft 2barrel carb, locked rear differential, shaved head, and 280 cam.
and can i also get you guy's oppinion on supercharged 2rz?
thanks in advance for info.
· Read Only
I don't know anything about the 2RZ, I have a 3.4L 5VZ engine that is supercharged & I love the extra power that I get from the TRD supercharger.
Mad Maxx
Discussion Starter · #11 ·
Sure it's different, it cost me a few thousand dollars to loose horsepower.. But it's different.. ;)
yur running carb? yea its different , dont see alot of tacomas running carb , tacomas mostly efi with k&n intake system and headers or turbocharged, and i love the torque the 2rz gives performance wise with a stock motor, its similar to a 22r full setup.
· ADMlNAHATER
Nope.. no carbs..
If you like the power it gives you now, carb's are just going to slow it down..
Stock their tuned pretty well.
I like the torque my fuel injection gives..
It's not "different", but different enough to move quicker.. :waytogo:
dont see alot of tacomas running carb , and i love the torque the 2rz gives performance wise with a stock motor, its similar to a 22r full setup.
I've never seen a Carb'd taco.
I dunno wat 22r you've drove but my rz will run circles around one. No were similiar on torque or power.
Wy not jus get a pre Taco an Carb it?? Waaaay easier an cheaper. Unless ur pockets have no bottem:D
that's jus my .02 tho. Good luck
Discussion Starter · #14 ·
i drove a 22r running 305 cam, port and polished head, stage 2 centerforce, 8pound flywheel, lockd rear differential, 44 mikunis sidedraft with nitrous 150shot and the body was chopped like crazy inside and out, and i raced a 2rz with turbo and i had to spray nitrous juss to cover some gap distance.
yea my pockets are tight cuz stil in school. all i got in my truck right now is a k&n filter and glasspack muffler and im still kiling hilux.
i drove a 22r running 305 cam, port and polished head, stage 2 centerforce, 8pound flywheel, lockd rear differential, 44 mikunis sidedraft with nitrous 150shot and the body was chopped like crazy inside and out, and i raced a 2rz with turbo and i had to spray nitrous juss to cover some gap distance..
Did it look something like this? LOL
i drove a 22r running 305 cam, port and polished head, stage 2 centerforce, 8pound flywheel, lockd rear differential, 44 mikunis sidedraft with nitrous 150shot and the body was chopped like crazy inside and out, and i raced a 2rz with turbo and i had t:waytogo:eek: spray nitrous juss to cover some gap distance.
yea my pockets are tight. all i got in my truck right now is a k&n filter and glasspack muffler and im still kiling hilux.
X2:waytogo:
1 - 20 of 22 Posts
