Re: Bulbs Behind Gauge Face
Check at either a Toyota dealership or like some electronics store, you can get different colored covers for those bulbs, blue might be cool. As far as changing them, you need to remove the black trim pieces around the stereo and insrument cluster, you may have to get the steering wheel collar off to get the main piece off, be carefull of the l/h blower vent it has an elbow on it that will hang up a bit. Then there is a few screws holding in the cluster piece, pull that out and disconnect the wires, the bulbs will be inside the rear. Sounds hard but not really
