building a 2rz turbo kit
2641 Views 11 Replies 9 Participants Last post by  [email protected]
i just got a t3/t4 turbo piping oil line bov and intercooler off my buddys honda. what injectors would be good i plan on 8lbs. and i need a manny?:shrug:
1 - 12 of 12 Posts
hit up [email protected] for a mani. just picked one up from him and he does real good work
good deal. yeah i was thinkin about the log style.
would 550 cc injectors be to much?
wont hurt but they wont be necessary under 10 lbs. maybe u can just give them to me! hahaha but get a 255 fuel pump too, and what engine management are you gonna use? and the log style is fine, but if you wanted he can make you a ramhorn too. whatever you prefer
If your just gonna push 8 PSI then the pink injectors and fuel pump is good.
What are you gonna use to control the injectors?
I vote for Urd MAF cal
I would run URD's MAF cal and AFR sensor calibrator or the MAP-ECU2 if I had the extra cash.
You should have a way to monitor your A/F ratio as well. I think the LM-2 would be cool for logging data and monitoring A/F. $400.00 on amazon.
I'd just go full standalone!:waytogo:
Yeah that would be the best. Who makes a good one? Cost?
if cost is an issue..............i would reccomend a piggy back of some type
Greddy Emanage Ultimate unit for sale in the in the parts section! I run one just like it!
:headbang: thanx bud...
buy once or send double later...
what is your end goal? if you plan on making good power with more boost/built motor buy the injector that will suit it now if not you will be on te small side and have to sell them to go bigger...
personally just go 750ish on the injectors... good for mid 400's idle will be fine with tuning..
and go full standalone ecu, with the $ you spend on this and that for these "piggybacks" and the headache you will have spent enough for a EMS...
Haltech, Microtech, AEM are all good ones,
I personally run Microtech and my fathers runs on a HAltech.
1 - 12 of 12 Posts
