got a chiltons or a haynes manual? its pretty simple. all you need are: two people, a big bottle of brake fluid, and a 10mm wrench (for tacos).
behind each wheel, there is a bleeder nipple (10mm). you want to top of the fluid resivior, have your buddy pump the brakes up then hold the pedal down, then you open and close the bleeder nipple for a second. repeat until all / any air has been purged from the lines.
repeat for each wheel.
you'll probably want to use a catch can of somesort. you can use small diameter vacuum line to connect to the nipple, and route it to an empty coke / pepsi bottle.
