1 - 20 of 28 Posts
· Premium Member
Ok i have a 01 prerunner running 33" allterrains. Well my gas mileage sucks ass. I have the airaid intake tube not the full intake, throttlebody spacer, and exhaust so far. Well i know that i need to re-gear it for better gas mileage. Well i was wondering if there was anything else that i could do to get better gas mileage. My goal is to get about 19-20mpg. I thats asking alot but theres got to be away to do it. I was reading on the deckmod. Ok i was wondering everyone says that its better then an intake. ok i have just the tube w/ stock airbox do you think ill notice a difference?:shrug:
I read an interesting article about gas mileage a little while ago.
in the first 4 reccomendations, Do not change the tire size, and Do not lift an SUV or TRUCK were there.
I was pretty annoyed, but to be honest, It's kinda dumb to try .. when all you have to do is take the lift off, and put some 235's back on.:jawdrop:
I'm getting 15/17mpg with 2.5" lift and 265x 75x 16s
It is horrible, but I gave up caring.
I'm currently getting 20.7mpg. When I had the TRD s/c w/2.2" pulley I was getting 22.2mpg. I put the s/c w/2.2" pulley fuel mods ect. on my buds truck and his mpg went from 17-18mpg stock to 19-20mpg. He stays in the throttle a lot though. I have factory ride height and tire size. For some reason forced induction seems to help mpg as long as you are not in the throttle all the time. :shrug:
My 3.4L 4wd xtra cab taco was getting 21freeway and 15-16 town. It had 270/70/16 A/T with a 2.5" lift in the front. My 3.0L xtra cab LT w/ 32 11.50's muds is getting 14-15 in town and 16-17 freeway.
You should be getting better mileage then 13. Especially better then my 3.0L truck. There horrible for mileage like the other guy said. Try using A/T tires instead of muds if you arent. Try electric fans. Full synthetic oils. Make sure your o2 and spark plugs are good and clean. Your air filter is clean. Could try seeing if sea foam helps. Make sure your PVC and fuel filter are good. Try being a little easier on the throttle too.
Im switching to A/T and going to put in a electric fan to see if that helps me out whenever i get the time and figure out how to install an electric fan on my truck.
I had the deckplate and i think i went up about .5-1mpg. I cant remember anymore.
Also URD sells like an Air/fuel tuning thingy. It should help on NA trucks and not just FI truck with power and better mileage. I was going to get it before i sold my taco.
· Premium Member
Discussion Starter · #12 ·
ya i know i have been slowing down on the gas. i dont care about being first off the line at a light, I have a brand new airfilter, i have 33" BFG A/T. If you do the math its 13 miles pergallon but bigger tires roller a further distance so im guessing about 15 MPG. I have stock gears. which i want to change for the new tires. Try a deck mod. but other then that i dont know what to do. the electric fan thing i wonder if that works. also less air conditioner will help. ill look into that URD thing u were talking about.
I think it was called the PSC 1 or something like that. Is the 15mpg around town? Cause thats what my 4x4 got and i had smaller tires.
What kit are you running on your prerunner. Your pics to small for me to check out the truck. I wanna see it.
all i know is i have a 3" procomp spacer and 33/12.50/15 BGF AT's. I'm at 16mpg right now and i drive about 70 miles a night city I went from a K&N filter with the deckplate mod to a cheapy Fram, and noticed the gas mileage went down significantly.
WOW you guys are lucky!!! I get about 11 MPG. I only get 180 miles to the tank if I'm lucky. Actually my last tank I only got 170 miles to the tank. I've tried everything from the tornado to different brands of gas! If I pull a trailer It still does'nt change the mileage. But I still love my truck!!!
1 - 20 of 28 Posts
