cant go wrong with smc's imo
dang $22! i paid 30-somthin for them awhile agoyeah, i've been running my 3/8" smc valves for years with no issues...i checked on suicidedoors.com a couple of weeks ago and they had a special on those too...like $22 each or something, sweet freakin deal so I would check to see if they still have it going on
2 valves for each bag, one fill/one dump...i haven't ridden in a truck with f/b only, but i imagine air transfer would suck in the corners1 valve for each bag
you can't link pictures from your computer directly to the internet..sorry i just reread my post meant would use a manifold setup like like this for each corner or just 2 separate vales
http://www.suicidedoors.com/files/imagecache/product_list/smc3_8-manifold-valve-system.jpg
yah my bad 2 valves2 valves for each bag, one fill/one dump...i haven't ridden in a truck with f/b only, but i imagine air transfer would suck in the corners
not to mention if you ever do have any issues, it's much cheaper to replace/easier to take apart to clean a single valve than a manifoldI haven't run across any manifold valves that are worth a damn. Best bet is to run 2 good valves per bag and set up accordingly.
Not only that, but SMCs tend to be the easiest to source parts for. The gasket and the solenoid you can get almost anywhere.not to mention if you ever do have any issues, it's much cheaper to replace/easier to take apart to clean a single valve than a manifold
