No, it is not that simple.
The DynoJet is super simple. It is a known mass being accelerated in a given time. The only reading from the drum is how many times it goes around. The calculation is simple. How fast you can accelerate that known mass in a given time comes up with an HP number.
On loading dynos they work completely different. They work on a strain sensor or load cell. As the eddy brake powers up to resist the rollers turning the stain sensor is deflected. Calibration of the dyno is now very critical. Known resistance applied against your engines efforts to turn it causes a defelction in the load sensor. It is easy to get this critical calibration a little off and this is the reason why laoding dynos don't always compare exactly the same even the same brand and model. All this does not matter when tuning as you are just looking for the increases, decreases and peaks in each cell in your EMS.
When you are doing an ongoing tuning project you should always use exactly the same dyno so the little error in calibration remains constant.
If you are using a loading dyno for acceleration snap shots you should keep using that very same dyno each and every time it is completely consistant. The max number really does not matter as long as you know if what changes you made make more power or less.
Just my opinion, but there are two top tuning chassis dynos, the DynoDynamics and DynoPack. Now once I was done doing development on a product or system, I would do a run on a dynoJet to publish that to the public so the numbers compare to what everyone is used to using and seeing.
A simple rule to live by, all dynos will report different numbers and they do not exactly compare with each other. So, when you see this guys dyno showing 188 don't go freaking out thinking that his truck is weak. I am sure if it was run on the DynoJet it would be were the rest the truck normally are.
Gadget
