How many bolts (total) did you remove?
Here (attached) are the 2003 FSM sections on front speed sensor components and removal.
I notice there seem to be 4 sensor harness bolts on a 5-lug setup, plus one(?) bolt for the sensor itself.
The components diagram seems to show two bolts at the sensor location. One of these is apparently the 4th bolt for the sensor harness, and the other is a single bolt holding the sensor.
The removal instructions make no mention of having to remove the wheel ... :shrug:
