Start with a compression check just to make sure your motor isnt the problem, let us know what the numbers are, should be within 10% across the board. I believe it should be around 140psi if I remember correctly.
Start with a compression check just to make sure your motor isnt the problem, let us know what the numbers are, should be within 10% across the board. I believe it should be around 140psi if I remember correctly.I have a 98 Tacoma 2wd 2rz with 196,000 and i'm having a low rpm hesitation, stumble. I have recently replaced the fuel pump and filter, sparkplugs and it has older msd wires on it. Any ideas? sorry if this has already been posted, I couldn't find anything!:brickknoc
That's another 'likely suspect', and it's another thing that might be wise to do before going to the trouble of a compression check. :thinking:If all the above doesn't work maybe cleaning the idle control valve?
i agree with cleaning the IAC...cant hurt even if it doesnt fix it.Fuel filter ? Are you gettin cel ? If the pull the iac wires off when it's running to see if there's a change at idle I did that found out it was the iac valve
or a vacuum leak somewhere, causing it to stall/surge at an idle, do you hear any kind of leak? i had a broken vacuum line once and it made the truck idle like sh!t, but would run fine when driving.
i would not think compression would be an issue, if its not blowing smoke, then chances are it has compression...
im not arguing just curious, what else could cause low compression? in a bascially normal common situation...[/color]
Untrue, a low compresion motor will not smoke due to compression loss, it will smoke due to bad valve seals or piston rings.
Just so people dont get misinformed.
I start with a compression test because you want to be sure your motor is fine before you get into the rabbit hole....only takes a few minutes.
I do this stuff as a profession all day long and I would say it is beneficial to start there just so you know if nothing else. If you didnt do that and it was the problem you could spend tons of money and time trying to diagnose a problem you missed.
Dont you want to make sure your pump (motor) is good before you check the little stuff? If there is low compression nothing else matters, my .02.
i understand the valves not seating, but if they arent seating, i would THINK that it was cause it to run like crap through all RPMS....not sure, never had real bad valve issues
