1 - 10 of 10 Posts
I had dealership install a 3/1 pro comp nitro spacer lift and I am hearing a weird noise from front going over speed bumps. I think the sway bar might be hitting cool the few pics are the clearance I have it’s not even enough space to fit a finger. Should I get a sway bar relocate kit?
Automotive tire Automotive lighting Automotive design Gas Auto part
Automotive tire Bumper Rim Gas Tints and shades
Discussion Starter · #3 ·
That’s what the plan was but I kind of wanted to go in with a idea of something to tell them what’s going on.
Don't see any visual contact. Check the 14mm nuts on top of the struts
I agree with pimpRunner - I don't see any obvious signs of contact / impact / rubbing in the photos.
If the pics do illustrate some such issue, please explain what it is in the photos that demonstrates it ...
  • Like
Reactions: pimpRunner
Discussion Starter · #6 ·
i thought when I went over bumps the sway bar may be contacting the bottom of coil?
What does the noise sound like, and why do you think it's got something to do with the sway bar?
Is there any sign of contact / impact between the sway bar and the coil(s)?
Discussion Starter · #8 ·
When I looked it did look like there was rubbing and it sounds Like a bang I can’t tell if it’s metal on metal or not. And I researched online and it seems like quite a few other people were having issues with the sway bar contacting the coil there’s is barely any clearance can’t even fit a finger in there. I have a video but not sure how to post a video here
Discussion Starter · #9 ·
Here is a link to YouTube. In the video listen closely. A noise from the front end. And the rear end.
1 - 10 of 10 Posts
