1 - 12 of 12 Posts
airbag light won\'t turn off
When i take the dash panel off around the radio and put it back on
the passenger airbag light always comes on on the instrument panel. The passenger airbag keyswitch it turned off. How do i get the red airbag light to turn off?
Re: airbag light won\'t turn off
no. the light turns on to let you know that you turned it off. at least my truck does that. just a reminder to let you know that it is off and turn it back on.
Discussion Starter #5
I searched yahoo and found that Crutchfield tells you not to unplug the harness for the airbag when you take the dash panel off.
Some other site says the light will stay on until the computer is reset.
I unplugged the harness so i guess i need to have the computer reset.
How do i do that?
Taco Fiend
To reset your comp just take the negative lead off the battery for like 5 minutes and then put it back on and presto chango it's reset.
Taco Fiend
now only the yellow "off" light is on, but it's less annoying, to me at least.
AZ
You can take the bulb out of that switch really easily. I had that same problem when I still had the switch and it annoyed the crap out of me.
Hello- Does anyone know if the airbag light should be on? The passenger seat is empty, and the airbag light is on. It's not indicating that it's (ON) or (OFF) but the word "airbag" is lit. Not sure of this is normal?
What year and cab style is your Tacoma?
1 - 12 of 12 Posts
