In closed loop you can't adjust the AFR (unless you have AFR sensor calibrator) the ECU will fight to stay 14.7 however there is something called fuel trims and if you add or take so much fuel that the Toyota ECU can't adjust the fuel trims to keep the AFR at 14.7 in closed loop you can have a lean or rich condition. That's why you have a P0172 and P0175 which are "too rich" codes.
Have you been playing too much with the map?
Load the base map or contact Gadget at URD.
