should i go with add a leafs or shakles....ive heard shakles make more sway...............whats the best?
wtf, i've never heard anyone recommend blocks before :looney:.hazardtanature said:I say neither do blocks. Shakles take away from load capacity and Add-a-leafs are heck to install. It mostly depends on how high of a lift you want to do.
I was thinking the exact same thing....ummm ditto what kevin saidCYi5 said:wtf, i've never heard anyone recommend blocks before :looney:.
if you don't haul a lot of heavy stuff or tow a trailer, go with shackles for better ride quality.... never heard of or experienced them causing sway. depending on how much lift your want, you could go with both aal's & shackles.:waytogo:steller199 said:should i go with add a leafs or shakles....ive heard shakles make more sway...............whats the best?
realiable than what? blocks? definately....more reliable than shackles? I don't think so.....I've heard of AAL's breaking...never heard of a shackle breaking.....not saying it can't happen......rmcclean12 said:Leafs for sure. Like it was stated before if you can turn a wrench you can add-a-leaf. Keep your load capacity and the more reliable option.
No and No....reason is because the shackle setup on the 05+ is different than the previous years....a longer shackle on a 05+ would actually lower the truck, not lift it.....Dragincrosmember said:Does any one make shackles for the 05+ or do the old ones carry over to the new model?
:funnyup: :looney: :funnyup: :looney: :funnyup: :looney:hazardtanature said:I say neither do blocks.
