Wouldn't it be cheaper and more straightforward to try and counteract the Taco Lean by manipulating the existing springs? :thinking:
Post a pic of your front and rear suspension. But it sounds to me like your front coils are shot. Just get some newer stockers (they go for cheap) and that should bring back a bit of lift and help with the leaning issue.yes it is a coil spacer lift, and i just put 285 m/t's on it. so from what i am gathering (i believe) is that the cause of this lean is from the saggy front coils, and not from the sagging, close to negative arch leaf packs?
is that correct?
beefed, those "shim" looking things, those tuck right under the leafs, and will be tucked in by the U-bolts?
thanks, guys.
mike
That's funny man.I put a sack of cement in my bed to level it out.
