95.5 Tacoma 4x4 Extracab- CALI truck/NO RUST
3RZ 4cyl.- wicked strong and reliable
NO accidents
clean body and interior
170K on truck- I'm 2nd owner, best friend was original owner- I know complete history on vehicle.
Stats:
ENGINE:
=50K on 3RZ engine(factory Toyota ) installed in truck less than 2K mi. ago in July 2009. Original owner( my buddy) had a thermostat freeze and overheated truck/blew HG. I found a great engine, out of a 96 taco w/48K original mi. that was the shop truck build for a fab shop(project was never finished/scraped), and bought it- easy decision to replace full longblock to avoid ANY issues and save rebuild time.
=Following installed at same time:
- thoroughly cleaned inside/out incl. wiring harness(truck original not swapped)
- AEM ShortRam Intake/Dryflow filter CARB compliant
- LCE Header ceramic coated
- LCE street clutch
- LCE 35# Flywheel w/new OEM fly bolts. Incr. torque for crawling/ no stall
- LCE underdrive Pulley
- LCE T.O. bearing/pilot bearing/Header studs/PCV valve/grommet/oil pan gasket/valve cover gasket/fuel filter/oil pump and seal/water pump/termostat/rear seal/rad. cap
- LCE magnecor wires/cap/rotor
- new cat. converter
- GY Gatorback belts PS 43", Alt./AC 34.25"ea.
- battery Autolite
- silicone hoses throughout
- upgraded starter/grd./fuse panel cables
= T100 oilpan swap kit for your SAS when you are ready
DRIVE:
- 5speed W59 trans. tight/ no leaks
- 4.10 stock gearing
- Stock 15X7 alloy rims
- 31.5" crappy tires with plenty of tread to get by ~30% left. Can get great deals on TireRack tires but not gonna install new for sale cuz tires are personal to each- let me know what you may want and we can add them in if you like.
- Manual Hubs/ NO ADD
- CV NO leaks/ NO rubbing
- drilled/slotted rotors
- Fabtech front +3" adjustable coilovers FTS2100K preformance. Set at 2.5"
- Fresh prof. alignment
OTHER:
- Factory Tow Pkg. receiver/trailer wiring
- Aux fuse panel in cab under dash
- Hella Headlamps
- Spray in Bedliner prof. installed years ago (has 2 bubbles but no tears)
- Chrome grill/ trim level
INTERIOR:
- tachometer(factory)
- tan 60/40 split bench and rear jumpseats- no wear/tears
- PW/DoorLocks/PS/rear slider/ Cruise/ hot heat/ AC (needs recharge)
- Eclipse CD8052 deck
- Rockford Fosgate Punch4080DSM 4ch. amp
- Boston Acoustic ProSeries 6.2 separates/ custom hidden enclosure dual 8"subs
BAD:
- no rear bumper (sold it cuz was gonna fab up a tube bumper)
- paint on roof faded
- minor body dings- DS fender top, rear corner above taillight
- A/C needs recharge
- front plastic valence pushed in at frame from dune razorback clearance issues
- tires 30%
- not a new truck
Great reliable clean build platform with many important things already tended to. Ready for your own personal touches to be added.
Only selling cuz i bought a new TUNDRA. Already have a crawler.
$7000
May accept partial trades for truck stuff.
Call/PM/email for any more info.
Aaron
760- nine one four- 08 six 8
[email protected] dot com
truck located in Mammoth Lakes, CA 93546. Possible delivery to SoCal or Reno areas???
