95 2.4 4x4 rebuild.
1471 Views 11 Replies 4 Participants Last post by  planemos
i just baught another taco. a wrecked taco. all the cab mounts busted up through the floor from the accident because of the hokey ass botd lift id had. so i need to rebuind the floor. and what i need is pictures of the gap in between the frame and cab. or even just the measurements of the four corners so i can begin the rebuild. thanx in advance.
1 - 12 of 12 Posts
I didn't know Tacos came with the 2.4L and 4wd. I thought they were all 2.7L or 3.4L.
maybe he's calling a pre taco a taco because in 95 you could get a 95 pre taco or a 95.5 Tacoma..
You better clear things up syktaco. What model is it Taco or pre Taco. Extra cab or reg cab. I can help you if it is an extra cab 2wd pre Taco.
sry guys im used to my 2.4 in my pre now:doah:. but no its a ex cab taco 2rz 4x4. but the body mounts will be the same on an ex cab 2wd.
if its a factory 4x4 tacoma, its a 3rz 2.7 ;)
I'm still a little unclear on what you need, syktaco ... :shrug:
Would frame dimensions showing the cab mounting hole locations be of any help?
i have all the dimensions but what i dont have is this gap measurement.
yes you are correct :selfbonk:
OK - I see now ... Thanks ...
Was the lift done with a kit? If so - I'm not sure there's a way to determine the correct elevation measurements without having someone with the same kit (or maybe the same amount of lift) measure their setup. :thinking:
im removing the lift. it was only some cheep ars 2 inch plastic spacers. im bringing the body back to factory height. i got my buddy bringing his 96 taco to my shop tonight so i should be good. thanx guys
Lucky. I wish I had a close by buddy with a Tacoma like me. 2wd 1st 2nd and 3rd gen are rare around here.
1 - 12 of 12 Posts
