7th injector Banjo Bolt
3839 Views 6 Replies 3 Participants Last post by  Stroked01SRunner
Anyone know the thread/length specs for what Banjo Bolt should be used on the fuel rail such as what the TRD 7th injector kits used?
1 - 7 of 7 Posts
Would it be M12 X 1.25?
The replacement banjo bolt used in the TRD 7th injector conversion:
http://www.customtacos.com/tech/files/5VZ-SC-7thInjConversion.pdf
... is listed as having this threading.
^^ Nice, thanks. So that specific document is for if someones older 7th took a sh*t and needed to replace it?
I'm not sure ... :shrug:
I located that document from the Tech section in trying to find out if anyone on CT had ever posted details on the banjo bolt's size and threading. I'm not clear at all as to what that TRD 7th injector 'conversion' is about ...
It seems to make you replace an older existing 7th that used a braided line to another 7th, housing and rubber line. Weird. But I suppose its safe to guess that is the correct size to make it happen.
... But I suppose its safe to guess that is the correct size to make it happen.
As far as the threading / diameter - yes, that's my theory ...
I compared the conversion document against an initial install document, and it appeared to me the only difference was the specific banjo bolt used. Only the conversion install document mentioned anything specific about the bolt's threading.
I still don't have a clue about length, though ... :shrug:
Years ago I ordered the double union part listed in the 2001 Tacoma manual on page SF-6. It was part number SST 09268-45012. I had my friend at Toyota order it for me and they kept sending the wrong part, but on the third try it did come in. At the time I used the double union fitting for a fuel pressure takeoff, but it can be used for a fuel connection. The dimensions of the union bolt I have is 12mm X 1.25 thread X 38mm long if this helps.
1 - 7 of 7 Posts
