1 - 1 of 1 Posts
Vendor
I figured I would list some in stock wheel options for anyone in the market.
Shoot me a message for best pricing
Frank
6x139.7mm Bolt Pattern Method 305 NV 17x8.5" Wheel - Matte Black (0mm Offset) MR30578560500
Wheel Tire Automotive tire Locking hubs Vehicle
Highlights:
  • A356 Aluminum w/ T6 Heat Treatment
  • Solid Matte Black Finish
  • Street-Loc V.1 Lip w/ Undercut
  • Replaceable MRW gold zinc lip bolts
  • Standard 6x139.7mm Bolt Pattern
  • Features 0mm Offset
  • Sold Individually
Street-Loc V.1 Lip & 12-Window Wheel
When looking for an off-road wheel, a beadlock variant is a nice option to conquer the trail. Method's 305 NV 12 windowed wheels come in a matte black finish that gives your truck an aggressive and rugged off-road look, but can function as a street legal wheel as well. Its Street-Loc V.1 Lip with an undercut mimics a true beadlock wheel. Replaceable MRW gold zinc lip bolts also add a nice look on your wheel's lip. Complete with debossed Method logos, you'll be the envy of everyone you encounter. You can trust the 305 wheel to get your midsize truck where it needs to go, on or off the beaten path! High-Quality Construction for Maximum Durability
Method's 305 wheel fits right onto your truck's hub and is built from high-quality components for longterm durability. This 17" diameter wheel is manufactured using A356 aluminum with T6 heat treatment so that it is strong and durable enough for practically any application but lighter than your original factory stock wheels. Each wheel comes with a standard 6x139.7mm bolt pattern that allows them to fit right on to your truck's hubs without the use of wobble bolts, spacers, or other adapters. These wheels include a 4.75 backspacing and a 0mm offset to provide a great look and the ability to use aggressive suspension upgrades without clearance issues.
Wheel Specs:
  • Size: 17x8.5"
  • Bolt Pattern: 6x139.7mm
  • Backspace: 4.75"
  • Offset: 0mm
  • Load Capacity: 2500lbs
  • Hub: 108mm
Fitment:
  • 2019-2021 Ford Ranger Ranger w/ 6x139.7mm bolt pattern
  • 2021 Ford Bronco 2-Door & 4-Door with 6x139.7mm bold pattern
  • 2010-2021 Toyota 4Runner 6 lug w/ 6x139.7mm bolt pattern
  • 2005-2021 Toyota Tacoma 6 lug w/ 6x139.7mm bolt pattern
  • Will not fit Bronco Sports
1 - 1 of 1 Posts
