Well, your leaf springs in the back will stay the same, just pull othe middle one of the leafs out, run mono leaf with the overload spring still in place. I imagine the lowered springs up front would be a little stiffer since they're designed to support as much weight with less spring, but since they would only be 1" (not much) drop springs they should ride pretty smooth, I doubt if you'd notice it much if at all.
