1 - 8 of 8 Posts
Called LCE today and they no longer offer boring service for 3rzfe throttle bodies, anyone know of a company that does? Thinking about measuring a few junkyard throttle bodies and seeing if an adapter plate would make one fit, even a sweet aftermarket drive by wire setup would be something to consider.
Supercharged, and my current ones butterfly valve has been rubbing against the bore of the tb. Adjustments dont do a thing it's not centered in the bore or the bore itself isnt perfect.
Yep. Been following your Hill Climb thread. May honestly have better luck over here: Turbo BS Thread
May not be better advice, but it would be faster given. This place is frequented more than here. Knowledge is knowledge, but sometimes you just want something running sooner.
Contact George at www.maxbore.com. I had my 5VZ-FE throttle body bored from 60mm to about 63mm. Also had the center shaft thinned. Top notch work.
  • Like
Reactions: Sleepn
1 - 8 of 8 Posts
