Noise best heard around 25+ seconds
This is on a 99 2.7 w a supercharger from LCE, youtube compression messed with the audio but the noise heard is much louder. So what is leading up to this noise is slight acceleration going uphill, 0-4psi according to the MAP, open loop, 2.2k-3.2k rpm, spark advance is around 10. All is well in closed loop but after a few seconds of uphill travel the ECM will switch to open loop, drop the afr from stoich to 10-12:1 (depending on what I have the active cells set to) and make this sound, power loss the whole time. Sometimes it will even do this on flat ground and make it impossible to accelerate without coasting for a few seconds to switch back to closed loop. No ammount of timing retard or fuel cell changes makes this sound disapear, leaning out the cells seems to help with power loss but then effect afr during the first parts of WOT (16:1) for a brief moment. I've never experienced spark knock before so I'm not sure if this is what it sounds like. For anyone with experience with SplitSecond MAF/Timing controller and R4 tuning software, messing around with overboost seems to do nothing as well.
10k miles on the engine and supercharger.
