2RZ/3RZ Supercharger with Split Second fuel/timing controller.
Included are four pulleys: 70mm, 63.5mm (2.5" URD pulley currently installed), 58mm, and 55mm.
Also included are two Supercharger manifolds, one is an 8 port the other, that is currently installed, is a 4 port.
All the mounting brackets, installation instructions, and Split Second software is also included.
This supercharger has been on two 3RZ engines and has about 30k miles on it. I changed the oil in it about 3k miles ago, when I installed it on the second engine. I used the oil from the maintenance kit that is also included. There are no leaks or strange noises and it work perfectly.
$2000 OBO, Local pickup only, no trades.
