1 - 1 of 1 Posts
2018 Tacoma TRD Off Road
2018 Cement Tacoma TRD Off Road 4D 5ft bed
37, 450 Miles
3” inch ToyTec Lift ( Toyota Dealer Installed - Warranty still valid )
Total Chaos UCA
(5) Fuel Hostage Rims on LT285/70/17 BFG All Terrain T/A KO2
T1 Series H11 Temp Control LED Headlights (AuxBeam Lighting)
Bedrug Bed liner
Recon 49” Xtreme Scanning LED Tailgate light Bar
48” Cast & Steel Farm Jack
Remote Start
STANDARD EQUIPMENT
  • 7" Hi-Res Tch Screen, AM/FM/CD, USB/AUX, Bluetooth, HD Rad & SXM
  • 6.1' Composite Bed w/120V Pwr Outlet
  • Entune Prem Audio w/Integ Nav & App Ste:
  • Coil Spring Double Wishbone Fr & Leaf Sprng Rr Susp w/Sport Tuned Shocks
  • 4WDemand: Part-Time 4x4 Sys w/2-speed, & Electronically Controlled Transfer Case
  • 17" Machined Alloys w/P265/65R17 Tires
  • Prjctr Beam Hdlghts w/Blk Bzls & LED DRL
  • Smrt Key Sys on Dr Door w/Push Btn Strt & Remote Keyless Entry Sys
  • Qi-compatible Wireless Smrtphone Chrgng
  • Pwr Wndws w/Fr Dr & Pass Auto Up/Dwn and Power Door Locks
  • Pwr Side Mirrors w/Turn Sgnl Indicators
  • Toyota Safety Sense(TM) P (TSS-P) Pre-Collisn Sys w/Ped Det (PCS w/PD), Lane Departure Alert (LDA), Sway Warning System (SWS), Automatic High Beams (AHB) and Dynamic Radar Cruise Control (DRCC)
  • Towing Receiver Hitch, Eng Oil Cooler, Pwr Steering Cooler, 130- Amp Alt, 4/7-Pin Connector, & Trailer Sway Cntrl
  • Tire Pressure Monitor Sys w/Auto Locate
  • Pwr Horizontal Rr Window w/Priv Glass on all windows
  • Lthr Trim Steering Wheel w/Audio Cntrls
  • Easy Lower, Lockable & Removable Tailgate
  • 3.5L V6 Atkinson Cycle with Dual VVT-i 278hp @ 6000rpm/265 lb-ft @ 4600rpm
  • 3-Pt Seatbelts for All Seating Positions
  • Deck Rail System w/4 Adj Tie-Down Cleats
  • Rear Backup Camera
  • Leather Seats w/Dr Lumbar Support
  • Dr & Fr Pass Advanced Airbag System Seat-Mounted Side & Side Curtain Airbags
  • 6-Spd Automatic Transmission
  • Preferred Owner's Portfolio
  • Mudguards
  • Automatic limited-slip differential
$37,999
135869
135870
135871
1 - 1 of 1 Posts
