1 - 1 of 1 Posts
2016-2022 Toyota Tacoma Rough Country Paintable Pocket Fender Flares (Flat Black) F-T11621
Tire Wheel Vehicle Truck Automotive parking light
Tacoma Rough Country Pocket Fender Flares Features:
  • Simulated riveted look
  • Added protection from rocks, mud, and road debris
  • UV protected to prevent fading
  • Easily paint-able to color match your truck
  • Easily removable
  • Quick and easy installation
  • 3-Year Limited Warranty
Aggressive Design and Added Protection
If you're looking to upgrade your truck with an improved and aggressive look without spending thousands of dollars on bumpers and lift kits, look no further than the Rough Country Pocket Fender Flares for your Tacoma. With these pocket fender flares you'll be able to achieve a tougher and more rugged look to the exterior of your truck. These Rough Country Pocket Fender Flares will also provide protection from rocks, mud and other road debris. The fender flares come finished in flat back and are completely paint-able to color match your truck so you can achieve a sleek and integrated look. Durable Construction and Easy Installation
The Rough Country Pocket Fender Flares are UV treated to prevent fading and are constructed from a special Tri-Blend ABS material for maximum strength and durability. These fender flares will have your back in just about any climate or environment making them a reliable product along with an inexpensive and immediate exterior upgrade. Installation is made a breeze with the bolt-on design that secures easily into a few mounting points without any required cutting, drilling, or permanent modifications. These flares can also be easily removed to bring your truck back to stock. Backed by Rough Country's 3-Year Limited Warranty to help protect your investment.
Flare Specs:
  • Color: Flat Black (Paintable)
  • Tire Coverage: 1 inch
  • Flare Height: 6 inches
Vehicle Fitment: 2016-2022 Toyota Tacoma 2WD/4WD
1 - 1 of 1 Posts
