1 - 3 of 3 Posts
Vendor
In stock and Shipping @ Stage3
2016-2020 Tacoma Morimoto XB LED Headlights Set (Black) LF530.2-ASM
135904
Highlights:
  • Better light output than OEM headlights
  • Well defined beam pattern
  • High intensity with the proper distribution of light
  • Sequential LED DRL
  • UV-coated polycarbonate build
  • Simple, Plug-N-Play installation
  • DOT Approved
  • Includes installation instructions & hardware
  • 5-Year Limited Warranty
High-Performance LED Headlights
The stock headlights in your Tacoma do their job, but for truly powerful lighting, you will want to upgrade. The Morimoto XB LED Headlights not only provide a sleek, aggressive new look to your Tacoma, and they also provide industry-leading power and performance lighting for any nighttime adventures. The headlights produce an intense, well-defined beam pattern that is both intense and adequately distributed on the road ahead. The high-intensity LEDs provide incredibly visible daytime running lights and outstanding light output during the night. The headlights feature black trim and smoked reflectors, giving them a neutral color scheme that gives them a subtle, modern appearance. Another feature of the lights is the ability to set them up to run as a sequential signal, though they can be run as traditional on/off style signals as well. The UV-coated lenses are designed to endure the harshest natural elements and keep your headlights looking sharp and clean into the future. The XB LED Headlights are fully DOT Approved and meet or exceed all SAE, DOT, and FMVSS108 regulations. Give your 2016-2020 Tacoma a powerful lighting upgrade with the Morimoto XB LED Headlights. Simple Installation & Exceptional Warranty
The Morimoto XB LED Headlights have been designed as a fully Plug-N-Play installation, making them some of the simplest aftermarket LEDs to install on your Tacoma. The lights plug directly into the factory connectors and include all the necessary connectors, seals, and pigtails required for installation. Morimoto includes all the necessary installation instructions and hardware and offers an exceptional 5-Year Limited Warranty to help protect your investment well into the future.
Specifications:
  • Traffic Pattern: LHD Only
  • Operating Voltage: 9-32V DC
  • Housing Color: Gloss Black
  • Reflector Color: Smoked
  • Running/Parking Light Color: White (LED)
  • Turn Signal Color: Amber (Sequential LED)
  • Optics: Tri-Kuria Optic LED
  • Housing Material: UV-Coated Polycarbonate
Fitment: 2016-2020 Toyota Tacoma
1 - 3 of 3 Posts
