1 - 1 of 1 Posts
Vendor
Back in stock @ Stage 3
If anyone is in need of a set, shoot me a message for special forum member pricing
2016-2020 Tacoma Bilstein B8 6112 Front Suspension Kit 47-234413
135867
Highlights:
  • Awesome off-road performance and great street ride quality
  • Features oil capacity, cooling and long-term durabiliy
  • Feature adjustable ride height settings
  • Corrosion-resistant zinc-plated finish
  • Includes two 60mm shocks, two spring seats and two springs
Excellent Performance and Off-Road Handling with Adjustable Ride Heights
If your 2016-2020 Tacoma is destined for aggressive off-road adventures, then Bilstein has your back with their B8 6112 Front Coilover Assemblies. These powerful suspension upgrades give your Tacoma awesome off-road capability and can soak up violent impacts from rough terrain, all while maintaining good street ride quality and fade-free performance. The Bilstein 6112 coilovers feature a large-diameter shock body and specially-designed coilover spring that both work together to give your truck a huge improvement in handling and comfort both on and off-road. The 6112 coilover assemblies even feature adjustable ride height settings using snap ring system, allowing you to set your truck at 0", .5", 1", 1.5", or 2" of front ride height to help you clear larger wheel and tire combinations while reducing your factory rake. The 6112 front suspension kit is a great choice for a truck destined for off-road applications on a budget. 60mm Shock Body with Digressive Valving and Bilstein Spring
The Bilstein 6112 Front Coilover Assemblies feature a durable construction with a piston and valving designed to handle aggressive applications. The coilovers are built around a 60mm diameter (2.36") shock body that has a much larger oil capacity than stock and features a zinc plated finish to help prevent corrosion. The shock assembly utilizes a gas-charged monotube internal design with a digressive piston with valving tuned specifically for your truck. The coilover assembly comes with a new Bilstein spring and billet spring seats that use a snap ring to fit into grooves on the shock body for ride height adjustments. The kit includes two shock absorbers, two cold wound coil springs and two billet aluminum spring seats. The B8 6112 kit comes with installation and ride height adjustment instructions.
Fitment: 2016-2020 Toyota Tacoma
1 - 1 of 1 Posts
