Vendor
These have been on back-order for quite some time, now back in stock and available at Stage 3!
for 2005-2015 Please send me a message, as these are in stock but not on the website.
2016-2020 Tacoma Bilstein B8 5100 Adjustable Front Shocks (Pair) 24-263108
135874
Highlights:
  • Improved On and Off-Road Performance
  • Offers more handling & suspension travel
  • Accommodates 2" Ride Height
  • Easy, Bolt-On Installation
  • Sold as a Pair
2" of Adjustable Height w/ High Quality Piston Front Shocks
If you are looking for a package to improve your 2016-2020 Toyota Tacoma's front suspension, then you may be interested in Bilstein's stock. When you want something that will make your truck actually perform as well as it looks, both on the road and off, you'll need a set of front Bilstein B8 5100 shocks. The shocks are each built around a 46mm digressive piston used with a nitrogen gas-charged mono-tube design for a fade-free performance in all weather conditions. The adjustable design features multiple OEM snap-ring grooves for different spring positions. Excels w/ an Improved Performance
Just like all of Bilstein's high-quality suspension components, the 5100 series front shocks are built from the ground up for performance, longevity and reliability. On top of their leveling and lifting abilities, the 5100s give your truck better handling by improving rebound, response, and articulation all while keeping your truck's street and highway ride crisp and smooth. An additional benefit is increased suspension travel while out on the road or trail. The shocks can do this after you easily install them right into place of your factory shocks and reuse your stock OEM coilover springs.
Fitment: 2016-2020 Toyota Tacoma.
Warranty Information: Each of these shocks are backed by a limited lifetime warranty.
