Here (attached) is the 2001 charging circuit wiring diagram. The 'positive' lines should be solid white. The ground lines off the battery should be either solid black or maybe black with a white stripe.
It's difficult to trace the line between the generator and the battery because it's part of a bundle that's all sheathed together.
It's not absolutely necessary to remove and replace the stock wiring. You can get the benefits of a big 3 by adding additional wiring in parallel to the stock wiring.
As far as wire gauge - the bigger the better is the usual advice. Most writeups call for either 0 or 1 gauge wire, but many concede you can do well with anything down to about 4 gauge.
There are many basic writeups on the big 3 to be found around the 'Net. For example:
http://www.isyougeekedup.com/the-big-3-car-audio-wiring-upgrade/
