1 - 3 of 3 Posts
Help, I am new and I am putting in a new clutch, clutch plate, throw bearing, pilot bearing, clutch master cylinder, slave cylinder, and fork.
I am throwing money at this and I am afraid it is just a lock ball pin? Has anybody had problems getting their R155 in gear? (all of them when cold and warmed up)
I have changed the transmission fluid with Redline MT 90, and have changed the grommets on the bottom of the shifter stick.
Please tell me if I am missing something here the truck has 168,000 miles and I bought it used so I do not have any work history. That being said the Dot 3 fluid in the clutch master cylinder is a dark color indicating contamination.
I am hoping I am not missing something.....
Has anybody replaced a lock pin ball on a R155? If so did it shift better? Where is it located on my trans?
Thanks
Welcome to CT!
Unfortunately, I don't even have any reference documentation on the R155.
Have you changed the bushings in the shifter assembly yet?
I'm not 100% sure what a "lock ball pin" is, but I've done my fair share of messing around inside a few Aisin gearboxes, but mostly just W series.
1 - 3 of 3 Posts
