1 - 1 of 1 Posts
Vendor
Tacoma SPC control arms in stock @ Stage3
message me for forum discounts
Frank
2005-2020 Tacoma SPC Performance Adjustable Upper Control Arms 25470
Font Bicycle part Circle Metal Fashion accessory
Highlights:
  • Improves suspension travel, handling, and tire wear
  • xAxis sealed flex joints
  • 0° to +4° of caster and ±2° of camber
  • Includes installation instructions and hardware
  • Limited Lifetime Warranty
  • Made in the USA
Designed to outperform the other ball-joint options available on the market, the SPC Performance Adjustable Upper Control Arms provide your Tacoma with improved travel, handling, and tire wear with the adjustability to manage the harshest terrain. The arms are equipped with greased ball-joints and xAxis sealed flex joints in bonded rubber sleeves, which aids in correcting the alignment angles and ride quality of your truck. SPC's control arms feature an adjustable, high-angle ball-joint that allows for up to 2 degrees of positive or negative caster adjustment and 2 degrees of positive or negative camber adjustment, making it simple to adjust your alignment after lifting or leveling your truck. Upgrade your Tacoma for any off-road application with the SPC Performance Adjustable Upper Control Arms. Built for Aggressive Applications
SPC's control arms are built to withstand the most aggressive applications. The control arms are manufactured from forged steel, giving them vastly superior structural strength than the factory control arms. The high-angle ball-joint is capable of 80 degrees of articulation, providing more travel over stock and preventing UCA contact with the coilover on leveled 4Runners. SPC includes all necessary installation instructions and hardware and offers an outstanding Limited Lifetime Warranty. SPC products are proudly made right here in the USA.
Adjustment Range: Camber ±2.0°, Caster 0.0° to +4.0°
Fitment: 2005-2020 Toyota Tacoma
1 - 1 of 1 Posts
