101 - 103 of 103 Posts
Discussion Starter #101
135282
I put some fat tires on the Taco today. 295/50R15 Maxxis Marauders front and rear. The front needed 1/4" spacers so the 15x10 3.625" backspace Mickey Thompson aluminum wheels would clear the brake caliper.
Discussion Starter #102 (Edited)
I added fender extensions to the fender flares. These are made in USA Pacer Performance 52-198 Flexy Flares 1-3/4" x 25'. They cost $72.
135283
Discussion Starter #103
I added an Addco #656 rear sway bar. It really helps traction when launching. Before the sway bar I was getting a whole lot of frame twist when launching hard. Now it stays level and just goes straight. At only $114 the Addco sway bar kit is a really good value. Around corners it is a lot more predictable also. The limited slip differential is a happier with both tires getting the same amount of weight.
